Installing a CJ grille and front clip on a TJ/LJ
jscherb
Wilmington, DE
Spoiler alert: You can't install factory CJ front clip sheet metal on a TJ/LJ, none of the parts fit correctly. But some have requested info on how I did it, so here goes...
Back in the early 2000's I had a rare CJ-8 Scrambler - the Scrambler itself wasn't too rare, but it had an export "World Cab" hardtop, which is very rare in the U.S. The Scrambler really wasn't an idea daily driver, even after I converted the carbureted 4.2L to fuel injection - I wanted something I could easily and comfortably cruise across the country from NY State to the Colorado or Utah trails, so I sold the Scrambler and bought an LJ.
I really liked the World Cab hardtop so I decided to design and build an improved version in fiberglass for the LJ. The result was the Safari Cab (now in production at Gr8Tops); here's the Scrambler compared to the LJ Safari with the factory LJ grille:
The Safari Cab worked out great and is still on my LJ 13 years later, but I also wanted the classic look of the CJ Grille. I began studying the CJ parts and discovered that the only dimension in common was the width of the tub - nothing else matched...
In the first two photos below, you can see that the TJ has a raised section in the center of the cowl panel but the CJ hood and cowl panel are almost flat. Also this can't be determined by the photos, but the spacing of the hood hinges is different, so even if you tried to bolt a CJ hood to a TJ the hinges won't line up. In the bottom two photos you can see the difference between the curve of the side of the hood and the curve of the tub; also the tub as a body line a few inches above the bottom of the hood and the CJ hood is smooth there.
Also, the engine compartments are different lengths - the TJ hood and fenders are a few inches longer.
Some people have bolted the CJ hood and fenders to the TJ, but the result pretty much always looks like a hack because of the differences shown above. Basically nothing from the CJ can be used except possibly the grille, and even that doesn't bolt up to the TJ - the TJ steering box interferes with the bottom of the CJ grille and the TJ radiator doesn't bolt to the CJ grille.
I studied the TJ and CJ parts for a long time and a breakthrough happened when I removed the cowl panel from my LJ to see what was under it - it turns out that the top of the TJ tub actually matches the slight curve of the CJ tub and the raised section on the TJ is just part of the cowl and hood, not the tub. In this photo I've bolted a section of a CJ hood to the TJ (I had to drill some new holes in the hood section to match the spacing of the TJ hinges) and you can see that the tub matches the hood.
Removing the small bracket in the center of the tub would allow a CJ-shaped cowl panel to be installed on the TJ. The bracket is spot welded to the tub, so drilling out those spot welds is all that's needed to remove the bracket. This was the only modification that was necessary to the TJ to do the entire CJ conversion, and if I ever want to replace the TJ sheet metal all I've got to do is bolt the bracket back in place using the holes where the spot welds were drilled out.
With this discovery, I began working on a CJ-style cowl panel that would bolt up to the TJ. Since making custom parts in fiberglass can be much easier than working in metal, I started by taking a factory TJ cowl panel (1 in the photo below) and making a mold from it (2). Then I made a mold from a the cowl section of a CJ tub (3). I molded a TJ cowl in the first mold and a CJ cowl section in the second mold, cut the raised section out of the resulting TJ cowl and spliced a matching section of the molded CJ cowl in its place (4). That became the final "mold master" so I made a mold of it (5) and then made a final CJ-style cowl in that mold that would bolt in place perfectly to the TJ tub (6):
I installed a CJ HVAC intake grille, made adapter blocks so the hinges could be spaced properly on the CJ hood but still bolt to the narrower bolting locations on the CJ tub, and this was the result - a CJ-shaped cowl panel that would match a CJ hood perfectly but bolt to a TJ tub:
Next I did the fenders. I came across a set of fiberglass CJ fenders on Craigslist which I bought to form the basis for the new fenders. First, they had to be lengthened in the rear to match the length of the TJ fenders, that was pretty easy. I wanted to use TJ flares on the fenders because of their larger wheel openings than the CJ fenders, but the curve at the front of the fenders doesn't match the flares, so I made an intermediate mold of the front curve, molded curves and grafted them to the front of the CJ fenders. A work-in-progress photo:
When those were complete they became the mold masters and I made molds from them. Next I had to deal with the inner fenders - I wanted all of the engine compartment accessories that bolt to the fenders to bolt in place on the new fenders, but the shape where the fender meets the grille is very different between the TJ and the CJ, so I made molds of TJ inner fenders, modified the front of them to have curves to match the CJ grille, and then made final molds from them. I made inner and outer fenders from these molds and bonded the inners and outers together with this result:
Bolted to the tub and a factory CJ grille:
The grille needed to be modified to clear the TJ's steering box, so I clearanced that and built a bracket to maintain the CJ grille's integrity around the cutout. I also designed and fabricated brackets that allow the TJ radiator to bolt up to the CJ grille.
The final part was the hood. I needed to match the curves at the cowl and the TJ's body lines, and the hood needed to be longer than a CJ hood to accomodate the longer TJ engine compartment, so I spliced together parts of a TJ hood and two CJ hoods to solve those challenges. Work in progress:
When all of the welding, metalwork and bodywork was done, I made a mold of the result, and molded a final hood. This photo was taken right after the hood came out of the mold, it's not been trimmed yet.
I bolted it all together in the workshop:
Next was priming and painting:
I took a break from the project to drive to Alaska; I did the Dalton Highway all the way up to the Arctic Ocean and didn't want to get stone chip damage the 500 miles of non-paved roads up there so I waited until after I returned to do the final installation.
Installation was pretty straightforward - unbolt everything from the inner fenders and the grille, remove the factory sheet metal and bolt the new fiberglass parts in place. I didn't even have to drain the radiator or discharge the A/C, I simply hung them from the garage door rails while I was swapping the grilles. The ropes holding them aren't very visible in this photo but you can see them if you look closely.
The end result.
The engine compartment looks completely stock, except for one thing - the factory CJ grille has a provision for a cold air intake, so I plumbed that to the TJ airbox using stock CJ air duct hose. According to my OBDII scanner, this does reduce the intake air temperature and I won't make any claims about whether the cold air intake does anything for performance, but since the factory fitting was there on the CJ grille I had to use it :). You can see the cold air intake hose in this next photo.
With that done, I made a new emblem for the rear of the tub:
And with that, the transition was complete and here's how it compares to my Scrambler:
I took the opportunity of crossing the Animas River above Silverton in 2014 to recreate this CJ-8 ad:
I designed the CJ Grille Kit so that it could be a production product if some company ever wanted to market it, and a few companies contacted me about it but they apparently weren't serious enough to go ahead with it. I do still have all the molds so more kits could be made if there's ever a need.
The CJ Grille Kit has been on my LJ for about 11 years now, through about 150k miles of highway and at least 5,000 trail miles and there have been no issues. Other than people always asking me what year my CJ is :).
I've left out many details and photos but hopefully I've told the story well enough. If anyone has detailed questions or wants to see more photos of how I did something just ask and I'll be happy to answer your questions or post more photos.
Also if people want to see what it takes to make a custom hardtop, I can do a similar post about the Safari Cab project.
The end result.
Hi
Planning on doing a similar project
Putting a CJ Front clip on my TJ
Are any of the custom parts
available
Regards RD
Hi
available
Regards RD
I still have the molds for all of the parts for the CJ Grille Kit, but I'm not in business to sell anything, sorry. I just design things and make one or more examples for myself and occasionally for a friend, but that's as far as I go. Often companies pick up my designs and put them in production, but that hasn't happened with this kit. But if anyone/any company is interested in putting the kit in production I'll be happy to discuss it with them. Until that happens I'll keep the molds in case I ever need to make replacement parts for my Jeep or if some other good reason comes up to make parts.
Good luck with your project, if you need any advice or have any questions about adapting CJ parts to fit the TJ I'll be happy to provide advice and guidance.
Hi
Thanks for the reply
I think I’m looking to look at using the back half of the TJ tub and the front half of the CJ Tub
Mounted on my TJ frame this way I can include the CJ dash
and get the TJ tailgate and rear folding seat
Any advice would be appreciated
RD
Reactions: FarFire70
Hi
RD
I you're going to go about it that way, my advice is to spend a lot of time planning the project - measure everything, figure out what you'll have to modify, what will fit and what won't before you commit... a few examples:
* Where will you join the two tubs? You might think cutting in the middle of the doors would be easiest, but the sealing surfaces of the doors are very different between the CJ and TJ tubs, so you really can't join the tubs there. Behind the doors? Wherever you decide to join the tubs, will the floors line up there or will extra fabrication be required? Will the body mount locations from the CJ front tub line up with the TJ body mount locations on the frame or will either the tub or the frame need to be modified?
* If you use the front of the CJ tub all the way to behind the doors, will you need to switch to CJ/YJ doors? If not you'll have to modify the striker on the tub, the CJ and TJ strikers are incompatible.
* The CJ front clip (fenders and hood) are several inches shorter than the TJ parts so the engine compartment will be shorter. Will the TJ engine/radiator/etc. fit in the shorter engine compartment? What about all the stuff mounted on the TJ's inner fenders? The CJ inner fenders are a very different shape so it probably won't be easy to mount everything on them. And since the CJ clip is shorter, the grille probably won't line up with its mounting hole in the front frame crossmember and you may have to modify the grille and/or crossmember.
* What about HVAC? You say you want to use a CJ dash, but the TJ system (ductwork, etc.) won't fit behind that flat dash.
* What about electrical and electronics? Will you find a way to mount the TJ instrument cluster on the CJ dash? You'll need it for the odometer, which is controlled by the PCM computer. The gauges are also controlled by the PCM so if you don't use the TJ cluster you'll need all new gauges, which probably means dual sensors for everything - one to feed the PCM so it runs the engine correctly and one to feed whatever new gauges you use (for example, engine temp sensor). Air bags? If you use the TJ steering column you'll have that air bag but what about the passenger side? What will the air bag controller do if you don't have a passenger air bag?
* What kind of top will you use? Since you'll be using the front half of a CJ tub, you'll have to use the CJ windshield. The top of that windshield isn't compatible with the headers on the TJ hardtop or soft top so you'll either have to modify your top(s), or use a CJ top.
I'm sure there are a lot more things to think about and adapt, this is just a quick list to get you started.
In my experience, spending a lot of time planning helps avoids problems during the project and helps keep the project from ending up being a hack job. Do enough planning to know how you'll handle all of the above (and more, this is just a quick off the top of my head list) so you can source all the components you need and do it right the first time.
As much work as it was to make the custom parts that I made, I think the way you're planning to go about the project sounds like even more work than I had to do, but whichever way you decide to go, plan it thoroughly before committing and good luck with the project.
Yup, the mold master parts, most of which could have been installed on a Jeep with slight modification even though they were made with slight differences specifically to make the fiberglass molds from, went to the landfill a couple of weeks ago because nobody wanted them and I no longer needed them since I kept the molds that were made from them. Could have almost been a bolt-on conversion with the few mods those parts would have needed. Oh well.
A bit late to the thread but this is stellar. #high5 @jscherb
Solid craftsmanship and problem solving. Bravo.
Well I'm still it the planning stage, Im taking the experts advice, lots of planning.
The current plan is an LS with TJ Rubicon drivetrain and still planning how to make it Half TJ and CJ
Lot of benefits with TJ Tub and soft Top, So grafting the front end is the most logical solution.
Thank you very much. The CJ Grille Kit has worked out very well; the homemade fiberglass parts have been on the Jeep now for years and there have been no issues with it (or with the homemade hardtop).
And even with over 225,000 miles on the clock, the "LJ-8 Safari" continues to be my "Jack of all trades" go-to Jeep. Here are a few of the things I've done with it since the original post in this thread...
Last fall my wife had business out of the country so being left alone, I headed west to have spend a week in Colorado having some fun off-road. These next photos were taken at Hurricane Pass; that day I had come from Gunnison, did Engineer Pass and then down into the Animas Forks ghost town, then up to California Pass and Hurricane Pass, down Corkscrew Gulch to Ouray to spend some time in the municipal Hot Springs there. There was still snow at Hurricane Pass in early September...
Doing the trails alone, I carried recovery gear; on the roof rack you can see a set of aluminum sand ladders. My receiver winch mount is on the front bumper and the winch in one of the photos is in the rear receiver with its cover on. Didn't need any of that gear on this trip.
The prior day I was exploring both sides of the Alpine Tunnel, first by visiting the St. Elmo ghost and doing Tincup Pass, then on to the (collapsed) east portal of the tunnel via a several mile hike, and then around the other side of the mountain to attempt the west portal but the last few miles of the train were closed due to a collapsed shelf section so this photo taken at the tracks near the closure.
I spent about a week in Colorado and did more trails than shown above, it was a great trip. Then, a little more than a month later back home the plow went on. For the past dozen years I put the plow on in November and it stays on usually until late March depending on the weather. I only needed it a few times this past winter, the rest of the time the Jeep stays in the garage facing out so it can plow its way out.
After taking the plow off in March, I listed it on Facebook Marketplace and it got a lot of interest but nobody was serious until I dropped the price under $100. It's a plow that would cost almost $3000 new but I figured after plowing my driveway for a dozen years it didn't owe me anything and since I wasn't going to need it where I was moving to and I didn't want to transport it there, I let it go very cheap.
About the move, I was living in upstate NY and I've now moved to Delaware so I spent much of April through July hauling stuff from the old house to Delaware with the trailer. I made at least 20 500-mile round trips with the trailer, although not all of the trips were done with the LJ, both of my other Jeeps did some towing as well.
In the process of moving I downsized a lot - got rid of a lot of molds and prototype parts I did for companies like MORryde. I did get rid of most of the mold masters for the CJ Grille Kit but I kept the mold so more kits or replacement parts for my Jeep can be made if there's ever a need to make some.
The LJ-8 Safari remains my favorite Jeep, I would sell my JKU in a second (right now I'm considering selling it and buying an Ineos Grenadier - https://ineosgrenadier.com/en/us/) and I would even sell my Retro Wrangler pickup before letting the LJ-8 go.
Well if anyone wants to put the CJ Grille Kit in production I'm happy to explore the idea with them; being a 100% bolt-on it's by far the easier way to add a CJ front clip to a TJ/LJ. The molds are now here in Delaware doing nothing.
I would think Nemesis or Genright would talk to you about the molds. That being said, what you have is so unique and cool, I wouldnt blame you for keeping them to yourself.
I’m a flat fender bug eye fan myself. I just finished my second M38 grille conversion (first one was in 2010 iirc). Stupid simple in comparison to your cj8 conversion (yours is epic), mine's just a M38 frenched into the inside of a TJ/LJ grille.
https://wranglertjforum.com/threads/cj-grille-nose-job-for-the-lj.80982/page-2
