Mummy bag tips for side sleepers
Bobohunter1776
Evergreen, Colorado, USA
Recently decided to upgrade my backpacking sleep setup after 5+ years. Ended up buying a 15 degree Mountain Hardwear bag, and tested it out elk hunting this weekend. Nighttime lows were mid to low 40s. I wasn't necessarily cold, but definitely colder than I should've been in that bag. My guess is it's because I'm a side sleeper and usually end up in almost the fetal position. Anyone have any tips?
What did you sleep on? The sleeping pad can be a bit influence on this.
Nemo Switchback. I bought it knowing I would be sacrificing warmth for weight with the lower R rating, but figured it be enough for most of my trips. For the one's it wasn't I was planning on getting a half length pad for my upper body/core area.
I have a Switchback that I usually put under my inflatable pad. It does seem to help.
What did you sleep in? I think bags are rated assuming you're in a small tent with full rain fly, a good pad, long underwear AND fleece pajamas AND a warm hat.
Reactions: freedom_in_4low
My suggestion would be a warmer bag and a thick base pad or cot.
I hate being cold. I bought a rectangular bag that is rated for -20 (maybe even -40). Down to teens I've been incredibly warm. It has a canvas outer, fleece inner and IIRC, a synthetic down material inside. Paired with either a cot (my go-to) or a cheap foam sleeping pad. The downside is its rectangular shape and canvas material which for elk hunting, would be too big, bulky and heavy if you trek to camp.
I slept in base layers. The comfort rating is 26 degrees so I should've been more than fine in just base layers with the temps we were in. I've always been taught to sleep in base layers unless it's pretty damn cold.
Reactions: srimes
If I was buying just for elk hunting I would 100% have gone with something like that. My highest priority though is my backpacking trips, so weight and ability to compress is a must.
Reactions: tworley
Agree with sleeping in base layers unless you've perspired even the slightest during the days hike. No matter how dry you think you are, even the slightest moisture will make staying warm a challenge... especially socks.
My experience with hammock camping for more than a decade of UL backpacking is emphasis goes to what's under you more than what's over you. Cold ground utilizes conduction (cold air for hammock camper uses convection) to suck the heat out of you. Change your pad before you do anything else.
I've done multiple nights sub-five degrees in the hammock with a zero degree under quilt and only a twenty degree top quilt and was perfectly comfortable. Top quilt is essentially a mummy bag that is open under you. I always opt for a warmer UQ than TQ.
I did an AT section hike in 2021 that saw five or six degrees overnight. Base weight was 13.2 lbs with the warmest insulation I have in a 55 ltr. Z-Packs Arc Blast. Quilts are all 950's with 10D nylon outside and 10D nylon taffeta inside. Often the fabric used for quilts and bags has more impact on weight and ability to compress than the fill rating.
And, keep in mind that if you're using a down bag, you can have a minus gajillion bag that will do absolutely nothing to keep your underside warm once the down is compressed. Down doesn't create warmth. It just retains it. (so make sure you're warm BEFORE you turn in or you'll struggle to get warm once you're in).
Again, emphasis on quality, warm bottom insulation.
Reactions: RMETeeJay
Reactions: srimes
Reactions: Shank
I also try to stay as light as possible for backpacking, but always carry a NeoAir Xtherm. Ground insulation makes a huge difference in overall warmth and, for me, good sleep makes the difference between a good trip and a bad time. It's very comfortable and crazy warm. As soon as you lay on one, you will feel the warmth captured. You can optionally shave weight by switching to a quilt instead of a mummy.
The cons are:
  • Pricey (however, they are made in the USA and very durable as long as you have some kind of protection underneath and choose your site wisely).
  • As a fellow side sleeper, I will say that all of their inflatables are a bit noisy as you move around but not enough to wake me once I'm down.
  • Weight (compared to your foam pad).
  • You shouldn't inflate with your breath because it introduces moisture which causes mildew and reduces the insulation's effectiveness. They include a sack to inflate it. I was skeptical, but it works well.
All that said, they do have other pads that are less expensive. Here is their Sleeping Pad Finder.
Reactions: MikekiM
Just got back from a 6 day trip with nighttime lows ~25°. Bag felt like about how it should for the rating and the only changes I made was a Western Mountaineering sleeping bag liner and stuffing my down jacket in the extra space at my feet as well as wearing a beanie which I stupidly forgot on that last trip. I was more than satisfied with how warm it was.
Old Alaskan tip:
Having slept in just a bag at -40 F, I recommend throwing an air activated handwarmer to the bottom of the bag next to your feet before you tuck in for the night.
They even make reusable ones these days, but back 20 years ago this was the secret to fight off cold feet.
https://www.amazon.com/dp/B00ABMRO74?tag=wranglerorg-20
Alternatively, an old fashioned rubber hot water bottle filled with boiling water. All that modern tech it's easy to forget we ain't the first generation to deal with the elements.
https://www.hotwaterbottleshop.co.u...guide-to-keeping-warm-with-a-hot-water-bottle
I hadn't been backpacking for a several years until last fall. Just car camping. I am almost always carrying some heavy camera gear with either my 4"×5" camera or my full frame 35mm kit and ultralight has never been a thing for me. On this trip I knew snow was a possibilty as well as a wide range of temps. I ended up way too hot and just wasn't that comfortable.
I remembered how much I loved those hikes and the time solo or with my wife in the mountains. We've been backpacking together since we were teenagers and both started well before that. We still have gear that has served us all that time, but things change. I'd swapped out my old TNF tadpole 23 for a Fly Creek UL2 years ago for solo trips and appreciated the 2ish lbs saved.
Before leaving I looked at a modern thermarest lent to me. It was only 3/4 length and I went another direction, but I was shocked that my old thermarests weighed in at ~4lbs and this was like 1.
When I got home I started looking at options. The quilts make so much sense for me solo. But as a first step I ended up getting a system for both of us with a feathered friends Condor filled for 10F, undersheet and hoods along with matching neo-air xtherms. No more trying to zip our mummy bags together. This system cuts about 8-10 lbs combined from our old setups and about 3-5 lbs when I go solo. I can't wait to try it this coming Spring. We can get a lighter warmer weather Condor later. A quilt is definitely in my future for solo trips.
Reactions: StG58
