Thank You in advance,
So basically I'm planning to buy the rusty's 4.5" long arm kit and want to make sure what I'm doing works and is smart.
*4.5" long arm kit-—————— Rusty's TJ Wrangler 4.5" Long Travel Kit
*4.5" RockJock Currectlync Heavy duty steering system (Tie Rod and Drag Link) (already bought)
* Rusty's steering stabilizer.———————————-Rusty's Stabilizers - Single Performance (XJ,TJ,ZJ,YJ)
* Rusty's SYE and Driveshaft.———————————-Advance Adapters NP231 SYE & Tom Wood 1310 Series CV Driveshaft
* Rusty's coil spring relocation brackets.—————Rusty's Rear Coil Spring Frame Relocation Brackets
I am currently running a rough-country lift on 35's with the SYE and stuff but man it is leaning quite a bit to the passenger side just from the springs being old. The original owner did all the lift before I got the Jeep. 1998, 5 speed manual.
What am I missing? Anything needing to be done or considered before I get this stuff? People seemed to be happy with Rusty's products which is why I chose the kit but other options would be nice for around the same price. Metal Cloak is out of budget. Also can someone explain, do I not need an SYE or something for the front driveshaft??? This is confusing if someone could explain that part. Why get an SYE only for the back driveshaft? Thanks, I think I asked all the things I need answered before I pull trigger on this.
I'm not an off-roading genius so any help is appreciated, I've just researched and asked other ppl.
