Pretty far outside. Slightly less than this.Will a 33x12.5x15 wide tire with a 4.0 backspacing rim be right at the edge of the fender ? Or will it be out side it?
Go for a 15x8, you can run a 33x10.5 tire all day long on it, but if you want to ever go to 33x12.5 you can run them too. A 15x7 is maxed out with a 10.5" tire.
Bore (center hub) is irrelevant on a TJ. The OEM came hub centric, but almost all aftermarket wheels for TJ's are lug centric. The lugs are tapered conical so they are absolutely fine to run. The bore being larger is absolutely fine. This would open up more options for you. Cheers!
Hi I'm new to these forms. How do I measure my rim size? I'm running 33x10.5x15. Just trying to figure out my rim size...15x7 for example. Do I need to remove the tire from the rim to measure?
Can you post a picture of your rims? If they are oem we'll know what the width is.
With a tape measure through the holes and a couple straight edges to reference the outer lips.
Ahh that might work! I just need the measurement from edge to edge?
Then subtract the thickness of the rim at the beads (both sides), since you're wanting the inside measurement. It's not like you need a precise measurement you're just trying to get to the nearest inch.
You should be able to see a stamping in the spare wheel.
Some manufacturers make 1/2” sizes too. My JK has 17x7.5
Is the stamping generally on the rear of the rim? I'll have a look tonight see if I can find it
It would be on the inside(rotor or drum side). You will have to take the spare off to make it easier to find.Is the stamping generally on the rear of the rim? I'll have a look tonight see if I can find it
33x10.5x15 Toyo MT's on 15x7 AR23 with 3.75 BS. Love 'em!
View attachment 25319 View attachment 25320
I like that rack too, what kind is it? What brand?
