FYI: Ordered a Stant thermostat from Amazon; received a Motorad
MikeO
Hallsville, Texas
Ordered this: https://www.amazon.com/gp/product/B000C7YRNM/?tag=wranglerorg-20
Received this: https://www.amazon.com/dp/B000C5E8XI/?tag=wranglerorg-20
After reading reviews, I see I am not the only one.
Reactions: Duner and L J
Same thing happened to me a while back except purchase was from Rock Auto. Same part number on the box. Read somewhere later that Stant exited the aftermarket market, sold the business to Motorad
Motorad purchased Stant who closed and sold their Aransas HQ in 2021. No idea if Motorad incorporated any of Stant's designs like their SuperStat into their offerings but early comments on Motorad's thermostats are not so good.
Reactions: TheBoogieman
I recently ordered a Motorad Radiator cap because I could not find the Stant in stock. It came in as a Stant. Maybe order the "wrong" one and get what you want.
Reactions: Hopper
I'm using the motorad 2000-195 with out issue. The mopar stats and superstant I ordered when doing a coolant refresh were all motorad but all still different. The 2000-195 has the jiggler valve.
I drilled a hole in thr 2000-195 and moved on with my life for 6 bucks. The thermostats are very easy to replace.
After seeing this thread this morning, I searched on the bay and the lead listing was for a pair of 195F SuperStats for $10. After completing that deal, I saw many listings for these. Y'all stock up. Oh, I also bought two of the RobertShaws from FlowKooler.
I hate shortages and insulate myself by landing deals when I can. Thanks to you guys who tell us of these situations.
Reactions: Jerry Bransford
As a point of reference, I purchased a t-stat advertised as MOPAR 52028186AC from Amazon a month ago. I received this in an Amazon box loose with no packaging:
I purchased a t-stat from RockAuto advertised as MOPAR 52028186AC. I received this in "MOPAR Genuine Parts & Accessories" packaging with the MOPAR inventory sticker affixed:
Reactions: Duner
I recently tried to order a Stant off of Ebay.
It was listed as an original Stant.
When I received a Motorad I bitched to the Seller and he refunded half my money.
I’ve had nothing but issues with these garbage motorad thermostats. I bought a supposed mopar one from “mymoparparts.com” and sure enough it was stamped with a motorad, I’m pissed.
I’ve seen a lot of people as of late have issues with motorad, and I can back that up. I just want a mopar one to be done with it, I can’t be asked to keep draining my coolant and swapping these things out if they are trash.
Reactions: L J
I don't have any experience with a Motorad t-stat but if they are an OEM supplier there maybe a difference between their OEM and their aftermarket t-stats.
Reactions: Duner
The 2.4 thermostat is located in such a position that replacing it means you also need to replace the coolant?
Reactions: Duner
Yes, the way it is positioned the upper radiator hose allows coolant to potentially flow backwards and spill out everywhere.
This picture isn’t the most accurate but it’s a similar idea.
