Gear pattern: a different perspective
Working on the Dana 30 this morning. Pinion depth at .065 - preload at 18 inlbs- backlash at .011. Looks to me like the pinion depth is a touch deep.
What does it look like if you tighten up backlash? There seems to be a discrepancy between factory backlash(6-10) and some later literature (10-15) for yukon. What gears?
Reactions: Peppergat
Revolution gears. They say between 6-10 for gear lash. I can snug up the backlash and see what it looks like.
Reactions: Rickyd
The issue with decreasing pinion depth is that the smallest shim I have is .010. So that’s what I just removed. That puts the depth at .056 which is the slinger thickness.
These are with the backlash at .008. The pinion preload is at 16. I think I need another .005 deeper on the pinion
