Nearly every year I have to flush my heater core to get any heat from my vents on my 2000 TJ. My blend door is functioning as it’s suppose to. I reverse flush it. I switch back and forth on each port trying to break anything loose that might be in the heater core. Each year I put clr in it for about 15 minutes and continue to flush the heater core. My entire cooling system has been changed several times over the last couple years. When I put the engine in I put a I believe it was a Cardone brand water pump because it had a steel impeller. Flushing the heater core helps but it’s still not producing excellent heat. It’s hotter and takes the chill out but it doesn’t get the inside warm enough to make me want to take my jacket off. This is when it’s 32 degrees and below outside. I flushed it again as I’ve done in the past. I pushed compressed air through it to see if I could break anything loose. I then tried blowing through with my lungs. There seemed to be some resistance when I tried to push through with my own breath. Not a lot but some. Has anybody tried blowing through a heater core? I just feel like it should flow as fast and hard as I could push through without resistance. Also when I idle the engine the air cools down some. I have a 195 thermostat. The engine doesn’t get hot when idling nor running down the road on hot days. It might warm up idling with the a/c on when it’s 90+ outside but cools right back down when I start moving or bring the rpms above 1000. I have the 11 blade Ford Explorer fan blade. I can’t help but think that my water pump may not be flowing enough at idle and possibly above idle or there is a plug in my heater core that I can’t break loose. The air gets warmer above idle but as mentioned it doesn’t get super hot inside. Other TJ’s I’ve been in gets plenty warm and can slow the fan down and take the temp off full hot. Thoughts???
