Full-Wave Rectifier / LED Turn Signals
Windrac
USA
All,
After installing high-clearance fender flares, I replaced the side markers with round 3/4" LED marker lights. Since the (at least the post-facelift) side markers use current one direction for marker and the other direction for turn signal flashing, these LEDs pretty quickly smoked. Apparently they didn't have enough of a reverse breakdown voltage rating...
So I whipped up a small full wave rectifier and ordered a ton of them, because economies of scale. It was literally cheaper to order the components for 20 boards than it was to order components for 4. Diodes I'm using are the S2210A from SMC. Rated at 100V / 2A and the board is designed accordingly. With an optional output filter cap for higher frequencies than, you know, turn signals. These will solder in-line and will be easily covered by heat shrink.
These will be useful for a handful of other projects I have too, and for future use. Being hilariously over-rated for this application they're pretty flexible.
Will keep ya posted once the SMD boards come in and I assemble them.
Reactions: SkylinesSuck
All,
I'd put a .1uF bypass for this application. Depending on the impedances involved, 47uF might introduce noticeable latency.
Nice work. My favorite solution is to rewire the side markers to work like a 3 wire bulb with two brightnesses. Use two diodes and a resistor at each. The resistor creates an artificially dimmed brightness and the turn signal is full brightness.
Reactions: Windrac
Whatever ceramic disk capacitor you have handy - will help protect the LEDs from current surges. Even a mic or two would be OK.
Rummaging around in my components drawer I found some 0.1u 250V film caps. That'll do.
Reactions: Zorba
How do you wire in the bridge rectifier?
This is how I'd do it. A small 20v 2-5 amp bridge rectifier is cheap and available at any electronic supply or even Amazon. The smaller the better, LED side marker bulbs don't draw much.
The side marker wiring voltage switches polarity when the headlight switch is turned on or shut off so this will insure the voltage fed to a simple 2 wire side marker LED light like I use will not change polarity. You'll need one for each side. It's of course not needed for incandescent bulbs like the factory installed. The side marker wiring side of the rectifier doesn't care which way the wires are connected to it.
https://www.amazon.com/s?k=20+volt+bridge+rectifier&crid=2PD3SBZMFCL7U&sprefix=20+volt+bridge+rectifie,aps,1802&ref=nb_sb_noss
Thank you so much.
I placed an order with Amazon hopefully I can get this taken care of.
Reactions: Jerry Bransford
Some of the LED bulbs have built in bridge rectifiers now. I bought some bulbs from Superbrightleds that were such, and also some eBay bulbs were too. Dunno if the front bulbs are available as such or not, just throwing this factoid out there.
Interesting...I've got Superbright LEDs bolt lights on mine...one died after a year...wonder if this was the issue.
