| 10/24/2021 | Purchased Jeep |
| 10/25/2021 | Added KC HiLiTES 1134 fog lights |
| 10/26/2021 | Added tube step bars |
| 10/30/2021 | Replaced ignition starter switch |
| 11/1/2021 | Removed Dixie air horns and eagle decal on hood. |
| 11/1/2021 | Replaced under hood light |
| 11/8/2021 | Replaced all weather stripping (doors, hardtop, cowl to hood, tailgate) |
| 11/15/2021 | Replaced steering gear with OEM rebuilt |
| 11/15/2021 | Replaced pitman arm |
| 11/15/2021 | Replaced drag link and tie rod with heavy Duty |
| 11/15/2021 | Replaced steering pump |
| 11/15/2021 | Replaced both washer fluid pumps |
| 12/3/2021 | Replaced steering stabilizer with Fox upgrade |
| 12/3/2021 | Replace 4 shocks with Billstein 5100 |
| 12/3/2021 | Replaced all stock control arms with Core4x4 Adjustable |
| 12/3/2021 | Replaced Steering linkage |
| 12/3/2021 | Replaced stock track bar with Core4x4 Adjustable |
| 12/3/2021 | Custom frame repair of driver side rear control arm mount |
| 12/4/2021 | Replaced radiator reservoir bottle |
| 12/30/2021 | Replaced cheap LED headlights with better LED headlights |
| 1/10/2022 | Replaced outer shift boot |
| 1/10/2022 | Replaced muffler |
| 4/23/2022 | Added Quadratec Adventure® Mirrors with Square Head |
| 5/22/2022 | Replaced aftermarket stereo, amp, and speakers with Jensen 710CW with Apple carPlay and Android Auto, requiring double din replacement center console, Alpine Speakers, Powered Subwoofer, Alpine Amp, including all new wiring and removal of some truly terrible wiring. |
| 5/22/2022 | Added storage tray above dashboard with integrated Apple MagSafe iPhone wireless charger. |
| 5/26/2022 | Replaced blower motor, blower motor resistor, blower motor resistor wiring harness |
| 5/30/2022 | Replaced HVAC controls, including re-wiring to add back on OEM connectors. |
| 6/2/2022 | Replaced hardtop with 2004 model, including replacing wiring connector on Jeep to match hardtop |
| 6/10/2022 | Added trailer wiring harness |
| 6/15/2022 | Custom fix for aftermarket header to down pipe junction, which are not the same size, causing exhaust leak. |
| 7/1/2022 | Replaced wiper blades |
| 7/1/2022 | oil and filter change |
| 7/2/2022 | Replaced Steering Gear with new Durango upgrade |
| 7/5/2022 | Replaced inner shift boot |
| 7/5/2022 | Replaced shift knob |
| 7/5/2022 | Replaced stock airbox and throttle body with CAI, 62mm throttle body, and Airaid AIR-310-510 PowerAid Throttle Body Spacer |
| 7/5/2022 | Replaced PCV elbow and grommet. |
| 7/5/2022 | Replaced oil filler cap |
| 7/5/2022 | Replaced hood hinges |
| 7/5/2022 | Replaces hood latches |
| 7/7/2022 | Replaced windshield |
| 7/9/2022 | Replaced clock spring |
| 7/10/2022 | Added D-Ring tow hook isolators |
| 7/20/2022 | Replaced NV3550 transmission with new |
| 7/20/2022 | Replace fuel pump |
| 7/20/2022 | Rear track bar mount replacement |
| 7/20/2022 | Rebuilt 231J Transfer Case |
| 7/20/2022 | Replaced rear driveshaft and added slip yolk eliminator, new pinion seals. |
| 7/20/2022 | Re-geared from 3.27 to 4.56 |
