NCSysEngr
Thanks for the feedback. Definitely dead! Not sure where all the corrosion (rust) came from. The jeep is pretty rust free for 17 OY LJ.Those are circuit breakers. Probably dead from all the corrosion.
Really nice "custom fit" job!Installed a subwoofer under the driver seat in the TJ (A detailed write-up will follow, when I get time) and Cam Position Sensor in the LJ.
FWIW. Moving my fan shroud was harder than doing the body lift. I gave up and did the MML with the riser blocks.Cool I will definitely look into it. I was planning on replacing the motor mounts anyways just because.
You're either really good installing a BL or don't know how to use simple tools???FWIW. Moving my fan shroud was harder than doing the body lift. I gave up and did the MML with the riser blocks.
You used to use those (if they're resistors) when the trailer had a 6 volt electrical system but the tow vehicle was 12.Removed these damaged "resistors" (?) from the trailer hookup wiring. (to prevent a short) Not sure what these are or why these were inline? Any ideas?
I plan to totally rewire the hookup so this wiring will removed / not be used.
You are too tech savvy with the new world. Shame on you.You used to use those (if they're resistors) when the trailer had a 6 volt electrical system but the tow vehicle was 12.
What's up with this 12 volt stuff anyway? 6 volts was good enough!You are too tech savvy with the new world. Shame on you.![]()
man, that does look pretty good. Nice job. You just weld up the holes? Also you mention "Mopar Caps" are they a plastic end cap? Why not weld a steel cap on and get some extra strength? Just thinking out loud here cause you have given me a bit of inspiration for mine ;-)Before…
After…
I cut down the OEM bumper, filled the holes and painted it, capped off the ends w/ mopar caps and mounted the Savvy winch guard… I think it turned out great!
I did something similar except when I cut mine I left enough face material to bend in on the ends for caps.man, that does look pretty good. Nice job. You just weld up the holes? Also you mention "Mopar Caps" are they a plastic end cap? Why not weld a steel cap on and get some extra strength? Just thinking out loud here cause you have given me a bit of inspiration for mine ;-)
I just miss driving it so now that there are no camping trips planned for my bus, I decided to swap spots so it is easier to take the Jeep if I want.![]()
Time to call in the big guns....Really nice "custom fit" job!
p.s. Why isn't there any hair on your carpet? Human, dog, cat, stray mouse, anything.![]()
Yep... they sure are broke !! lolThose are circuit breakers. Probably dead from all the corrosion.
Thanks… I don’t have a welder so I used jb weld epoxy putty stick and pressed it in from the backside and when hardened I sanded the front down and used spot putty if needed… already had the caps so I just cut the bumper to match the caps… easy peasy!man, that does look pretty good. Nice job. You just weld up the holes? Also you mention "Mopar Caps" are they a plastic end cap? Why not weld a steel cap on and get some extra strength? Just thinking out loud here cause you have given me a bit of inspiration for mine ;-)
Is you driver seat a fixed base?I'd love to read your write-up on the subwoofer install. I'm thinking of doing just that... same S.O. subwoofer in the same location.
Took the boy to get a haircut in the Jeep naked. For the last two weeks I haven’t driven it due to rain chances most days. Then it doesn’t rain, so today I said “up yours weatherman!” Well joke was on me, managed to get under an overhang for the worst of it, but it was a real cold and soggy ride home!![]()
