33x10.5 tires versus 33x12.5 tires
I'm going to go for 33x10.5 so will got for a 15x7 rim.
I'll order them today but can someone just confirm these specs please.
Wheel Bolt Pattern: 5 x 114.3m - 5 x 4 1/2 in.
Wheel Diameter: 15 in.
Wheel Width (in): 7.000 in.
Backspacing (in): 3.750 in.
Offset: -6.00mm
Center Bore Diameter (in): 3.300 in.
Center Bore Diameter (mm): 83.82mm
I know the center bore is larger, but can't find any in a 15x7 with the correct bore. I can always turn down some ring spacers.
Offset: -6.00mm
Go for a 15x8, you can run a 33x10.5 tire all day long on it, but if you want to ever go to 33x12.5 you can run them too. A 15x7 is maxed out with a 10.5" tire.
Bore (center hub) is irrelevant on a TJ. The OEM came hub centric, but almost all aftermarket wheels for TJ's are lug centric. The lugs are tapered conical so they are absolutely fine to run. The bore being larger is absolutely fine. This would open up more options for you. Cheers!
I'd still go for a 7" rim.
I've burped a 10.5" tyre on a 8" rim before and bead locks are not allowed on road cars here.
Could have been a tire shop issue. What did you air down to? I think you’re very safe down to 10-11psi with a 10.5” tire on a 8” wheel
That was at 12psi.
When I changed to 7.5s I got as low as 7psi and had no issues.
This was in a Suzuki so quite a light car.
I run 26-28 psi on 31’s. I only air down for serious off-road, probably once every two months, down to 12
Reactions: TheWreckining
Really?? That's cool! How's it working out so far? Recovering some nice Deer?
So far only have used for setting up stands. Weather has been against me all season. Only deer I have seen I took out the only branch between us
