2004 jeep 4.0 engine noise... read lots about all possibilities, I've made a post about engine issues before... Was hydro-locked. Thought it was lifters, replaced all, and wasn't it, wanted to get in there and check out the engine anyways so was a good learning lesson. Popped the valve cover too, everything is getting lubricated with 0 noises, and when my head is close to where the oil pan meets the tranny (manual) I get the noise the loudest/ clearest. Going to check compression and see what that tells me. If compression checks out fine, I am assuming piston slap or a bad bearing but probably piston slap as there was no metal in oil so my best bet says it is not a bad bearing.
