.i can't find info on the output spread dimensions for the NP231 i'll have to run out and get under it, it's 19*.........................i don't wanna but i will.
go it.....9.5".
go it.....9.5".
You have the FS kit? What makes it "rough"?I have that kit but it's rough. I was going to originally do that but decided to go with the doubler kit. If someone wants the parts for the NP231 doubler I can get all the parts and I'll sell it for 50% of that price, I'll never use it but it's going to require some fab work on their end.
OH are you talking about the black unit? *EDIT* yup okay I'm getting caught up now on all the pages in this thread, I jumped in without knowing everything yet!
go it.....9.5".
I wonder how close one could get to the stock 231 offset by clocking the 300 flat?So a D300 is just shy of 1" narrower than the NP231. Interesting for sure.
I'd sure like to have some type of mock up case to be able to see how a D300 fits. I'd be curious to see what had to be done to get it to work with the 46RE.
And I wonder if the Jeep 44RE or 46RE is different? Have to try and do some searching and see what I can come up with.
the 231 sits flat across and i already had to move/rework the trans fluid lines that had a wide bend on um and got into my travel zone.I wonder how close one could get to the stock 231 offset by clocking the 300 flat?
Man I just dont think $2200 for an aluminum case is a good investment. Just tough to justify. Add 4-1 gears, seals and you are over an atlas.Here is the NP205 offered by Behemoth Drivetrain that is getting installed in a rig for KOH. It's a rig from Rily Racing. https://www.facebook.com/RileyRacing4504/ and is being setup by Rock & Road Performance https://www.facebook.com/rockandroadperformance/
https://fb.watch/aBv3prArcd/
https://www.facebook.com/BehemothDT/
https://behemothdrivetrain.com/
for sure since you are tight as is, 1-2" inside and you'd have a good bit more to sort.I should be happy I have the STaK's
Haven't watched it yet but this popped up in my YT feed this morning.
ok i thought i saw the 1st atlas design was based off of the 300 is that true?
if so how'd they get another inch in the output separation into the design later?
i wonder if the use of a doubler box giving it more length could maybe get it a tad better angle from that further back point.
Price aside, size especially and weight also are the biggest consideration for me as a means to getting a 4:1 ratio. It seems an Atlas is a tight squeeze with a tummy tuck and length is also a limfac with a TT because DS angles. Less weight is just a very desirable bonus for me.
ok maybe i thunk wrong , quite possibly i'm always on the verge of spilling info to seep more it.Actually I thought it was mentioned that it was based off the NP205. Which based on measurements makes sense
once they get 205's going maybe he'll be doing an affordable case.
Midnight is $1400 I think.Yes I'm hoping Midnight has a better price point than Behemoths prices. I'd like to see it around $1500-1600 and you add the internals.
A stock NP205 is like the STaK's in they are both pigs. I think a stock 205 weighs over 100lbs and my STaK's is 150lbs.
Stock 205 is 130-140lb I believe.Yes I'm hoping Midnight has a better price point than Behemoths prices. I'd like to see it around $1500-1600 and you add the internals.
Yeah, it's $1400, then you need the 4:1 from JB Conversions which I think is about $700. Do you need anything else other than a longer driveshaft?Midnight is $1400 I think.
