STICKY Jeep Wrangler TJ Factory Service Manuals (FSM) & Technical Documentation
OK...took a little research and I have found the complete 1997 TJ FSM. It appears to have 1666 pages as opposed to the copy you have. which is around 300 less. I've tried to attach it but I was told that the file is too large. Not sure what the best approach would be. Zip file or splitting the pdf? It is 44.5 MB as it stands.
Email it to me at admin@wranglertjforum.com and I’ll take care of it. Just make sure you zip the file or Dropbox or to me.
Reactions: JeepNWilly
Reactions: SSTJ
You might wanna check. The pdf viewer that I used typically counts the number of actual pages vs the page numbers and it was definitely short. No prob with emailing if that's what you want.
Yea, I don't doubt that yours is more complete; I just meant that the previous version did have Section 25.
Shoot, I just spent 30 minutes re-arranging the order of the sections in the original copy, and now your version is trumping mine!
Reactions: ATLparanormalOG
@JeepNWilly / @Chris - apparently the FSM for the 97 is actually the FSM for 2003, which has resulted in much confusion for me over the last 24 hrs.
I'm looking through the 97 FSM but I don't see any mention of year anywhere in it. Granted I didn't read the whole thing, but skimming through it I don't see anything.
it's been quite the topic on my "reverse light woes" thread. In the VIN section it specifically says "3" for 2003, and apparently the compass/temp/mirror section was maybe first available on the 2003. I guess it's too big to upload, but I have my hands on the correct 97 FSM if you want to get ours corrected.
Yes please, that's actually what I was after. I just downloaded them all but have not had a chance to look at them.
Thx for the heads up.
(at least) two dead giveaways: in the very beginning there is a VIN decoder which references 2003. Then in the wiring diagrams there is mention of a compass in the mirror, which wasn't available in 97.
But unfortunately the biggest giveaway is that the whole thing looks like it was printed in 1966, whereas the other years looks like they were properly rendered. With all due respect to whoever did the actual 97, of course. It's invaluable and I'm glad to have it in any form.
I also noticed, since I was looking up the HVAC system, that the controls have the round dials. My TJ has the "sliders" instead. I believe that changed in 2000 models. So which file is the correct one for the 97?
Thank you.
