The blue thing is called a "bling ring". If bling is your thing.....
The lug/tread really popped in the mounting pics, those are huge.
you need a bit for your cordless drill. i might go nuts twirlin that T bar for 1/2 an hr.
Looking good brother! You can finally get your shit together!About here is where things went to SHIT.....
I went to put air into the tires and kept having leak. I tried every trick I knew and sprayed a TON of soapy water onto the back of the rim. I'd gotten the back bead to pop against the rim but still had a leak. I'd say this is one time hearing aids SUCK because I couldn't figure out what direction the leak was coming from. It sounded like it was coming from the front and back at the same time. Man talk about getting frustrated. This was around 1:45 PM and I spent an HOUR messing around with the tire and rim trying to find the leak. I had a ratchet strap on the tire and everything.
About this time I did the SLAP on the FOREHEAD deal and realized I hadn't looked at the Rapid Air valve stem Jeff had installed on these rims. Sure enough damn think was OPEN and it was my huge air leak. I closed the valve and BOOM the tire started taking air like it should. Now I won't repeat the things I was saying about @NashvilleTJ but I figured he was sitting back having the laugh of the year about this time. I honestly don't know if he'd mentioned that he'd left them open or not since it has been so long since I'd got these rims from him. This was about 2:45 PM and my daughter came out to tell me she was headed to work. So I had to do this.
Not the same but for this old sentimental guy it's close enough.
Not bad. 37.5" tall with 40 PSI pressure in the tire.
Damn but that is SEXY.....
Back around 2 PM I was thinking about mounting a second tire today.. Guess what? I decided that I wasn't gunna.
Either works, but with your york, I’d bet the the Monster valve may be faster. What I always did when airing up was to attach my pressure gauge to the small Schrader, and the air source to the monster valve. That way you can monitor the actual pressure while airing up.Jeff,
For the monster valve stem is there a difference between what is used on your Power Tank and what I would use with my OBA system?
@NashvilleTJ
https://powertank.com/collections/monster-valves/products/monster-chuck
You have that chuck in the link, right?
But you got the one I sent, right?Damn they sure are proud of that air chuck aren't they? $55 WOW....
There should be a bag attached to one of the wheels with that chuck, a spare valve or two, and a bunch of spare o-rings as well.I don't know? It must be in one of the boxes I haven't opened yet. I've only opened two so far.
I didn't realize you'd sent it along with the rims. DAMN Thank You a LOT.
By the way, make sure you keep the o-rings lubricated with a silicon based o-ring lube. You may remember what happened to me when I once used petroleum jelly on them. Not a good result...
Oh, and either sprinkle water or listen close for tiny air leaks.View attachment 295826
