WJ Lower control arm for a TJ?
Rickstar321
Lifetime Supporting Member
NEA (Jonesboro)
TJ Rubi Dana 44 rear swap. Just need to make it solid for a year until I get ready for bigger upgrade.
A buddy shared his WJ control arm swap he did for his XJ, just curious if anyone knows if this will work for our TJ's?
I already have adjustable for the top but still running stock on the bottom. Just wondering if this would be an inexpensive upgrade worth doing?
Haven't measured yet but I think the TJ's are 15", and these show 19-1/2"..? but not sure about eye hole to eye hole.
https://youtu.be/0orWZLxbk-A?si=rkvHFPHv-gGJNID8
Love them XJ guys and trying to find every low buck solution out there. If your arms are worn and need replaced the WJ arms are fine to use. If all you are looking at is not bending the stock arm just turn it upside down. Yes if you play in the mud they will accumulate crap but by putting the box end towards harms way they are less likely to bend if you rub them on something.
Reactions: freedom_in_4low
