I was able to determine that I need a new starter by running the tests described in the very helpful opening post by Chris at "Jeep Wrangler TJ won't start? Read this!" (https://wranglertjforum.com/threads/jeep-wrangler-tj-wont-start-read-this.1201/). Then, after seeing that I needed an E12 external torx socket and buying it, I was able to get the bolts out, which should have been the hard part. But now, with the starter loose, I cannot get it out. It will not come straight out and drop down, as would be expected. As I start to back it out, it forces itself to angle upward at the far end, and this far end of the starter runs into the engine pan. This stops the starter from getting far enough out to drop free. What is the solution for this strange problem?
