Ok super weird. Other than obvious signs of rods or piston movement...I don't hear any clapping or knocking... What other factors can lead to plug gaps shrinking from .035 to .031 within a couple of weeks weeks?
I've been going through my TJ and tuning up different systems. Swapped out the plugs with NGK V-Power Nickel Plugs (ZFR5N). They're pre-gapped to .036 although I checked the gaps prior to installing and they were at .035 per my feeler.
Had some misfires recently so I just wanted to check out what whas going on inside. Popped off the plugs to see if they were telling me anything and I checked the gaps again. Totally surprised that my reading was a tight .031 and shocked that .004 would shrink off in a matter of weeks.
Plugs seemed normal. No crazy carbon or uneven markings, for 2 weeks old plugs that is. A couple were a tiny bit moist.
I'm still getting a misfire and occasional stall at about 2000 rpms, (intermittent stall) but I suspect the CPS and TPS are due. (Currently throwing p0320 and p1596)
Are the diminishing plug gaps concerning right now? I plan to recheck in a few weeks.
