I replaced my harmonic balancer and timing cover/front seal a few days ago. So far no leaks at all, but I remembered that there was some sort of resin/glue on the harmonic balancer’s washer from the factory when I went to remove it. I believe this was to prevent oil from potentially leaking through the keyway on the crankshaft, even though the key itself should ideally block oil.
As long as there is no leak, I won’t worry about it, but I was wondering, is it recommended to put a ring of rtv behind that washer before tightening down the bolt?
