Reusing NP231J Output Shaft Snap Rings
TJRD4
NC
Having a challenge finding the Np231j output shaft snap rings for a 1.18" output shaft; the 1.375" OD output shaft appears to be more common (and is used on SYE kits). For reference, these snap rings are used just outside the output shaft bearing, then outside the output shaft seal (rearward of the spacer/washer). The originals are the triangle type retainer rings and not the two hole snap ring design.
The original snap rings were quite bent open hence why i would rather replace than reuse. I bent them back close to their original shape but am concerned with reuse.
Checked with advance adapters, ebay, and many other places online with no luck.
Reuse? Any other ideas of where to look? Maybe mcmaster/grainger? Thanks
