- Price
- 50
- Location
- Ashburn, VA
I have a set of Quadratec 4 inch LED flood lights available. They came off my 2001 TJ that I had mounted to the factory harness using an adapter plug which worked flawlessly. They are super bright and only about 3 years old. They only issue is I noticed they were pretty much stuck to the adapter while cleaning the Jeep to the point where they could not be removed. This bothered me to no end so I ended up replacing them with a set of Rigid fogs to change up the look a bit.
The problem is that I had to almost destroy the Deutsch plug to remove them. You can still plug them in as is but water resistance may be a concern if you submerge your Jeep since I had to break parts of the plug to get them off. Because of this, I am asking $50 shipped to the continental US including the hardware from my Rigid set so you can plug them in as is or splice them in.
