2000 4.0, 32RH Auto.
Recently took the transfer case out of my Jeep and rebuilt/replaced parts of it. It had a TeraLow in there and I put a normal 231 back.
My transfer case issue was solved, but first time driving it I noticed some odd behavior from the transmission.
When putting it into drive, i'll give it a little gas and it won't go anywhere, then suddenly it will lurch forward and go. This has happened a few times where i'll go from reverse to drive, park to drive, or neutral to drive. (sort of the same feeling if you release the clutch too hard on a manual, but not as jolting)
Then I've noticed some harsh downshifting from 3rd to 2nd getting on the onramp, intermittent, and once from sitting at a stop sign while in drive, harsh engagement when pushing on the throttle.
Fluid levels are good, as I checked (while hot in neutral) after putting the transfer case back in, and filled accordingly.
The Jeep did sit for almost a year while I rebuilt the transfer case, so the first time I drove it I thought maybe it was just a little sticky from sitting, but i've been trying to drive it often and it's still doing it intermittently, most commonly after it's been parked, after i'm driving around for awhile it seems to go away.
All procedures and precautions were taken when doing the t-case work, transmission was supported, everything went back together just fine.
I replaced the transmission filter and fluid just last year so it's fresh.
Any ideas on if I caused something and if so what? We were very careful not to pinch any cables or mess with anything else other than the transfer case lever.
Thanks.
Thanks.
