Jeep 4.7 Stroker Long Block Upgrade Kit $2500 Seattle, WA
Wildman
Over Analyzer Extraordinaire & Attention Whore
Staff Member
In the hills of WA
https://www.facebook.com/share/1G9j5Sxh4o/
This is a stroker kit from Titan Engines ready for assembly. Rotating assembly balanced by Pacific Auto Machine in Renton. They also checked everything over, honed the rods, and decked the block. Also includes new balancer and flex plate (used during balancing), a set of 23 lb Bosch injectors, break in oil, filters, and assembly lube. See photos of included parts. Roughly $5k in parts and machine work (in 2020). This is a great upgrade if you have a worn out 4.0 and are thinking about rebuilding. Head is an 0630 (96-98), not mounts for coil packs Block is a 53010449 NVH block (99-01 XJ 99-04 TJ and WJ)Camshaft is Elgin E-1122-PThis is a later style block that uses the thrust plate cam retainer instead of the pin and spring style.
