Hey guys, I have a 2006 Wrangler TJ Golden Eagle with the 4.0 and nsg370. I put a new clutch kit in last night and I fear I may have put the friction disc on backwards by mistake. I know which way it is SUPPOSED to go, I just can't remember if that's actually how I put it in. It drives fine, shifts fine. the clutch feels softer than it did before. There was a little rattle that almost sounded like a loose heat shield when in 1st or 2nd and under load. Other than that, everything seems fine. Do I really need to pull the trans again to verify the installation of the clutch plate? Would it be hard to shift or obviously noisy if it was in backwards?
