The following has me stumped
2006 Jeep Wrangler Rubicon, bone stock, no electrical mods of any kind.
1.) without any pattern I can hear the turn signal ticking but no dash light is illuminated
2.) when driving and using the turn signals, when the brake is applied, the indicator light in the dash illuminates continuously and doesn’t flash. When the brake is released the light works as designed
3.) the issues described in #1 and #2 only occur occasionally, never to a pattern
4) I’ve checked all light lamps for function and no issues. When the headlights are on, the issues occur the same as when the headlights are off
5) The 4WD operates fine but no indicator light on the dash
No other issues so far. The vehicle lights work fine in all regards. Then for no identifiable cause, start malfunctioning.
Any experience with this problem? What do you think? I’ve checked all wiring, can’t find anything.
thank you
thank you
