Idle RPMs
WVJeep304
WV
I'm trying to figure out if I have a problem here, and I think I do. On cold start, my Jeep kicks up to 1000 rpms and sits there for a while. After anywhere from 3-5min of idling, it works its way back down to around 700rpm. I'm thinking this wasn't always the case...I was thinking that it would hit 1000 rpm upon startup, but then within seconds idle down to 700. Does this sound right? I've smoke tested (never completely cold, though) and checked everywhere for a vacuum leak and found nothing.
I've also cleaned the IAC with no change. I have the IAC from my old TB laying here that I may end up swapping onto it to see if it makes a difference. This TB is a used OEM one I put on about 2 years ago when my OEM one was leaking around the throttle shaft. My original IAC on my OEM TB worked fine, so I assume it would be worthwhile to swap them and see if there's any change.
Anyone else deal with this? Any other ideas? My only other thought is that maybe my intake manifold may be cracked on the bottom or something where I can't see it. The only way I could smoke test it cold would be to leave it at a buddy's shop over night and then test it the next morning, but the logistics of that make it a less than desirable option. And my least favorite thing in the world is removing/reinstalling intake and exhaust manifolds on this Jeep, so I don't want to just take them off without definitive proof if I can avoid it.
Is it really cold when you start it?
Basically all vehicles made within the last 30 or so years have some type of cold high idle mode to help warm up the engine and catalytic converter faster for emissions reasons and to prevent stalling. The idle should drop to normal as the engine warms up
No, it sits it my garage which I keep at 60-65°. I daily drive my TJ and only notice this on the first startup of the day. I'm familiar with cold weather high-idle, but this doesn't seem to fit that. I don't recall it ever taking this long to drop back to normal idle. I was thinking it used to happen within 5-10 seconds.
