How much work to change a carrier vs regear?
deadbeat son
Denver, CO
My TJ's Dana 30 has 4.56 gears and an Eaton E-locker. I bought a new (relatively) TJ Sport yesterday, and will end up regearing it to 5.13 and would like to go with E-lockers front and rear. As I prep my old TJ for sale, I'm contemplating removing the locker and installing an open carrier so I can reuse the locker in my new build.
Is it close to as much work to set up the existing gears on a new carrier as it is to regear completely? I understand the pinion depth should be set, but can the carrier just be shimmed to the same specs as the locker that I pull, or is there more to it than that? Obviously I'm someone who has never worked on differentials (other than changing the lube), and I don't do the best with fiddly tasks.
Thanks!
Changing carriers is easy. You measure backlash before taking it apart and replicate it on the new carrier.
That said,you do need a dial indicator and magnetic base,torque wrench,press and maybe bearing puller depending on how its shimmed.also shim kit that may or may not have what you need.
Reactions: deadbeat son
Since the pinion depth is good, it would be quite a bit less. You still have to find the right shim combination to set your backlash and carrier preload, but it's not nearly as much iterative assemble-check-disassemble-adjust.
Thank you both! I think I would take it to the shop that did my previous regear, but evidently they went out of business. 🤷🏻‍♂️
Weigh increased resale of your jeep w/locker vs hassle and cost of the swap. How much will you actually come out ahead?
That’s exactly the math I’m contemplating. I think it would depend on the labor cost to swap carriers. I’m not sure how much value the locker would add to resale, $250? $500?
Labor,gear oil,carrier and bearings,misc shop costs. Subtract that from a new elocker.
Then how much you can upsale your tj w/locker? Luck plays a role there?
