Has anyone replaced body mounts and not broken bolts?
10 mount bolts came right out, the center front was very tight and squeeked most of the way out. I was able to PB blast the top side through a small crack into the void on the radiator support. The end of the bolt was wet when it came out, so it may have helped a bit, but I still needed a 1/2" breaker bar.
Anti-seize, when you put them back in.
