For background, I have recently (in the past year or so) installed rebuilt Curry control arms upper/lower/front/rear, Currectlync steering, Curry Track bars, and a SwayLoc. The noise didn't start immediately after I installed any of these. It's been at least 6 months with all the above parts as a matter of fact with no noise.
I have developed a pop/clunk coming from what I'm almost certain is the front and probably the driver's side when I toss the Jeep hard to the right while on road. It's just one pop/clunk and is not repetitive or speed related. Doesn't do it when I saw the wheel back and forth while sitting still. Doesn't do it when I turn hard left. I can easily repeat it by swerving back and forth real hard while going like 5mph down the road.
I thought for sure it would be the typical loose track bar bolt thing. I didn't see any signs of any bolt being loose and sliding a bit at any and every joint I could think of, but I tightened everything and threw parts at it. BMB control arm washers and track bar bolt/flag nut. Still does it. I can't detect any play in the unit bearings when I jack the front end up and try wiggling the top/bottom of the tires. I'm kinda at a loss. Any suggestions?
