Door Gaskets
ffcol
Colorado
I have received 2 different manufacturer's door gaskets this week and neither fit correctly like the factory ones. I only installed one since the replacement for that one looks exactly the same. The door does not shut flush and there is a large gap at the top where you can see daylight. Anyone know where to get oem gaskets or at least aftermarket that fit correctly?
I've been searching for over two years with no luck as of yet, think I'm on my third passenger side and it's just as shit as the previous two. No one makes them properly and with the correct rubber types, as far as I can tell.
I have full doors and just received the Fairchild and they are the same as the Accupart which I installed on the driver's door and it sucks.
I've had Dorman, Fairchild and APDTY. I think the last one is not so much an actual brand and you might get a different seal made somewhere in SEA depending on when you buy. None of them had properly formed features and all of them leaked as bad or worse than the worn out factory seal.
  • Sad
Reactions: L J and JMT
i used an omix brand and it is the best fitting aftermarket full door seal i’ve run across. omix is on the drivers side with an oem mopar on the passenger side.
