Does this new distributor cap look bad?
Kevin E
Lifetime Supporting Member
Wharton, TX
Does this look bad? Hatd to tell from the pic but it had a lot of "powder" corrosion on the contacts. Replaced the cap and rotor with Mopar and it seems to idle better. Maybe it's a placebo effect. Time will tell cause I've been getting coded for cylinder 6 misfire and 3 came up also.
The Mopar cap with brass contacts is a good cap, the aluminum contacts just do not seem to hold up as well. If your wires are showing their age you might consider that also.
