Before I go dishing out the clamshells to WranglerFix to check out, or replace, my Power Control Module (PCM), I was wondering if others would be willing to put their two cents in about my Jeeps current calamity. I've got a 2002 4.0L Inline 6. At first, I had the check engine codes p1495 and p1682 and my alternator was only charging to 12 volts, but it was charging. I replaced the alternator and battery and there was no change in how the car was charging. Just prior to taking it into an automotive electrical shop I got the code p0443. The guys at the shop said, unsurprisingly, the PCM was at fault for the charging problem and that all electrical connections and grounds looked good. As a bandaid to the problem, they strapped an external voltage regulator which is maintaining a nominal 14 volts on my system. Overall, I've now got the following codes in simultaneously:
- p1682 - Charging System Voltage Too Low
- "Charging system output voltage low."
- p1594 - Charging System Voltage Too High
- "Battery voltage sense input above target charging voltage during engine operation."
- p0622 - Generator Field Not Switching Properly
- "An open or shorted condition detected in the generator field control circuit."
- (expected considering the external voltage regulator is in place of the PCM regulator.)
- p0443 - Evap Purge Solenoid Circuit
- "An open or shorted condition detected in the EVAP purge solenoid control circuit."
- p1495 - Leak Detection Pump Solenoid Circuit
- "An open or shorted condition detected in the Leak Detection Pump (LDP) solenoid circuit."
