I'm doing a re-gear on my arb lockers and the install kit came with 7/16 bolts the carrier is drilled for 3/8 ring gear is drilled for both. So I guess ill have to order the correct bolts. Am I able to use the old bolts to set-up the gears then change them out after? or will that cause some sort of issue I'm not thinking of?
