SOLD Center Console Subwoofer Upgrade
Gilly11277
Dekalb, IL
Price
$150 + shipping
Illinois
I have a very lightly used Kicker 6.75” CompRT (48CWRT672) and Kicker 200W amp (PXA200.1). I purchased these new to upgrade my center console subwoofer. I ended up doing a complete overhaul of my Jeeps audio system so it’s time for these to find a new home. Great for anyone looking to boost their Jeeps sound system without breaking the bank. Fits right into the factory center console with minimal adjustments.
Amp
Sub
PayPal F&F or Venmo.
Is this the speaker and amp that will replace the speaker and amp that's in a 2005 console.? Does the amp fit in the console or does it have to mount elsewhere.?
Thanks in advance, I'm very interested..
Any idea on shipping to 46060?
While you can power this sub off the factory amp, you will get more power if you use an aftermarket amplifier. There is no room for this amp to be placed in the center console so you would need to find another spot for it. Luckily this Kicker amp is small so it will easily fit under a seat or below the steering column on the drivers side.
If your Jeep came with the factory sub option then yes, this sub should fit but you will need to make some slight modifications. Nothing hard and no special tools needed. Just have to remove some plastic webbing inside the box.
This is a sweet deal for quality sound. Basically, you're buying the amp and getting the sub for free.
Also, OP I like your jeep ;)
Reactions: Gilly11277
I just installed my new amp so I’ll also include the power and ground cables I used. Might not be enough for your install, but I have no use for them so you’ll get it free!
Great little sub. Since I already have one, Would you sell the amp separate?
And following up, I already have the amp, so would you sell the sub to me?
EDIT: Wait, that's the 2-ohm version, right? I think I need the 4-ohm dual voice coil.
Someone mentioned they are interested in the set. Yes, it's the 2-ohm.
Are you close to stl?
Edit: never mind I checked your location . Sent pm
Waiting on a response from an interested buyer, if it falls through I will move onto the next person.
