Hello everyone,
Started having this problem with my Jeep on first drive, it has an idle drop issue and will stall if I sit at a red light or stop sign for too long. After driving and the coolant temp. comes to normal range everything is fine, and the Jeep idles normal.
- Replaced the CPS - no change.
- Replaced the TPS, better idle than before but didn't solve the issue.
- Cleaned IAC, followed the forum's instructions on how-to. No change.
My next course of action was going to be to unplug the 2 upstream O2 sensors to see if this is what's driving the issues. They were recently replaced by a Jeep mechanic here on Long Island in the summer when an engine check light came on (came on after I had a bunch of work done, brake lines, transmission lines, next exhaust (only muffler and exhaust pipe, didn't touch Catalytic convertors).
I have attached a couple of videos too better help understand what I'm facing.
First drive of the day, let it warm up for about 10 mins to see if it would help but to no avail.
This is me restarting the car after it stalled, as you can see after a few seconds the idle drops then picks back up. if I don't put it in neutral the engine will die. Usually this will occur before it stalls, but this morning it didn't even fight, just died.
This is after driving about 5 - 10 minutes (4-5 miles), idling perfect at a red light. Coolant temp at optimal range.
Any help would be appreciated! this forum has come to my aid more than a handful of times, created a profile just now because I can't find a solution for this issue.
