recently finished a swap on my jeep with a 5.9 and 46re out of a dodge. Drove about 5o miles and it threw a p0713 code, I wasn't worried relooked at my wiring and can't figure out what I did wrong. everything is wired to the pinouts. the sensor has voltage, If I test the signal on the sensor it reads 5 volts.... so I knew that was wrong it should only read 2.33 or less or it throws the code. the ecm side of the signal is sending the wire 5 volts. Why is the ecm sending the signal wire 5 volts? can anyone help me fix this code or has a process to test to narrow down the issue ? I don’t believe that the sensor is bad, rather test and prove what is the issue rather than throwing parts at it. Anything will help thank you ALLL!!!!
