Well after much searching. I was not able to locate the 4748939aa gear. However, The gear for the 2.0 is readily available. (Dodge neon 2.0) It is the same diameter and the teeth, shaft, keyway, and timing mark are the same. However, it is about 1/8 in thicker. My solution is to machine down the inner recess on my drill press with a Forney 2 in grinding stone, checking depth to compare with the old broken gear, then when that is finished, simply grind the top to the proper thickness. Total cost $20 for gear, $7.50 for grinding stone. Pics to follow.
