Took the better-half down to the creek this morning.
Sent from my iPad using Tapatalk
Put the doors back on for the first time in 3 months. :( Most likely to stay on until next spring. I hate our long winters.
Reactions: jeepXcore
I can feel your pain for the last 2 weeks, depending on the day I've been swapping back and forth between my half and full doors. I finally gave in and put my door surrounds on.
Love those TrekTops. When my Craigslist special top gives out, that is what will go on mine too!
What did I do today? Finally finished prepping my JK take-offs for paint and primer...
I have them primed and drying. I'll be filling a couple area where I got a little "aggressive" with my grinding disc...
51imRGFYWlkyx1cVYxMrfoRzPcenfmdm218p35YnbY2dj7SateHOvUMTBo_lm-B49p0RTBXYA9bj_UJJ_A=w1135-h638-no.jpg
Painted my stock swaybar. It just looked bad
Before
After
Funny thing was my wife jumped in the TJ during this process and drove across the property. I left the bolts on the bumper. Oh well, I found two of them!
Tried to fix my high beam headlight issue last night....bear with me while I try to explain lol
You pull the knob out once for side lights and twice for main beam but the main beam doesn’t stay pulled out enough to trigger the lights...I have to use a peg (cheap mod ;) )to keep it extended enough for them to work but it doesn’t always work as a slight bump in the road and out go my lights...(just my headlights though)
Is there a screw of something I can tighten to make sure it stays on when the lever is pulled out or am I looking for a new switch behind the light lever? .
