I was an ASE certified tech for over a decade, I ran (and still do kinda) a shop for almost a decade. I've seen and run almost everything you can , both in my own cars and in customers, and while its anecdotal, here's my two cents.
1. like Jerry, Chris and many others have said, the number one thing for longevity and reliability is to just change your GD oil on a good service interval.... period! This alone will do more than anything else combined
2. I personally use synthetic in everything I own. I have never seen ANY evidence that synthetic will start oil leaks EVER. Its my opinion that's an old wives tale.
3. High mileage oil is a gimmick, there is no such thin as a mechanic in a bottle, these will not fix your oil leaks or help an older engine (read more I will explain more in a moment).
4. I use synthetic in everything I own. Again anecdotally, I have personally seen better wear protection (IN MODERN ENGINES) using synthetic over conventional. but my main reason is my wife ability to tell me her car needs an oil change, approximately 1000 miles past her actually due. I buy the cheapest full synthetic I can and the best filter I can, the oils are all the same!
There is a problem here that no one has yet brought up! API certifications
The reason I say that the oils are all the same, is because for the most part they are. The API cert on the side of any normal bottle of oil you pick up ensures that. FED EPA standards "requires" the use of API certified oils in modern vehicles to lower green house emissions. This means pretty much everything added is regulated, or it don't get the cert! Thus, there all the same! No more 12 herbs and spices, to magically keep you going. MODERN cars are built for this and run best on this, HERES THE PROBLEM
The 4.0l is not modern, far from it and some of those herbs and spices cut from the list of approved goodness is Zinc and Paraffin, not good for cats and the environment, but essential for flat tappet lifters. In my mind the question has never been, what brand, but instead API, NON API, or additives. just my 2cents
