Rusted torque box and floor support
Wampaging
Northwest Indiana
I just got a 97 TJ yesterday for my first car, I am thinking repairjng this would be my first priority. What would be the best approach to fixing this and what would be the best kit to get to fix it, I have to replace 1 on passenger side and 1 on driver side probably could do 2 on drivers side.
this is what you need. I have one here waiting to be put in when I get not lazy!
Ok that looks great, how hard was it to strip everything out and what you have to use/do to install,I'll look at that one, thank you
They have a YouTube video at rust repairpatch.com that show the steps. I used a grinder with cutoff wheel and sanding wheel. The hardest part was getting the rusted bolt out of the body mounts. I replaced four body mount.
I used the rust repair patch sections on my Jeep-center body mount on each side. I used the extra long sections-well worth it. Paint and rust proof the inside section first ( you will have to grind some paint off for a proper weld), and then follow up with some Eastwood Interior coat or something like it after the repair is done so you can help it last a long time.
