+1 ↑ This is exactly the leak mine had.Check at the firewall where the heater hoses connect. Just above them is the vacuum line that goes through the firewall with a check valve. It is a pretty tight bend on the plastic vacuum line. Mine had a crack/split in the line that was next to impossible to see until I disconnected it and straightened it out. I ended up cutting the line and slipping a small piece of rubber vacuum tube over it to fix the problem.
