Yikes
I'm changing my hubs and front universals.
The passenger side hub does not want to come out, I've been pounding and soaking, it won't budge.
Tried little steel wedges, no luck so far.
Maybe heat?
Will I damage my diff if I use a wheel puller and push on the axle? That doesn't sound like a good idea to me. Otherwise I may have to cut it off with angle grinder and carbide bits? Ouch
The splines are free on the axle so that's not it.
This is turning out to be a bit of a project. I guess since they've been in there 21 years they don't want to come out.
1997 TJ SE
Maybe heat?
1997 TJ SE
