I use straight water (with inhibitors) in my Jeep.Amazing that there are millions of buildings in this world that use straight water (with inhibitors)
Straight water is actually a better coolant for heat transfer then glycol is
If the radiator cap is a proper 18lb and working water will not cause any issues.
I did not suggest or advise that using water was proper,
You kinda did.
