Looks like an OBD port with a cover on it.
Have you (or can you) pull the plug (loop part) out to see what happens?
Anti theft device pull it out it will be a chip without it your engine will not start
Tumor.
Surgery needed.
I would remove that thing and everything connected to it.
Agree I had one on my Dodge. Dealer installs it and if you don't purchase the option they install the loop. If you do buy the option then they give you a FOB that has to pressed before the vehicle will start.Anti theft device pull it out it will be a chip without it your engine will not start
Leave it be. If you pull it out you will not be able to start the vehicle.And risk f'in something up? There been no trouble from it
True you could always plug it back in unless they epoxied it in! Just kidding.Pull it out and try starting the vehicle. See what happens.
That's where I would start.
Better to remove it in the comfort of your driveway/garage then be left stranded on the side of the road somewhere wondering why the vehicle is suddenly possessed by evil spirits.
