I removed the seat belts yesterday too and they were significantly longer bolts. Can I ask you to test that Torx head for fitment, it looks correct to me, but mine in a T-50
Regrettably, mine are T40’s. I don’t have any larger ones in my stash.
Here are the actual bolts I snapped. This Jeep was a 2001 and not sure if boys sizes changed over model years.
I appreciate both the thought and the effort. Thanks!!!!
Bob
Ok I hope we haven’t given up yet, there’s a good chance you can loosen the broken extractor by hitting the bolt from under and the same with a punch from the top. If you can loosen it, it should come out, if you have a strong magnet maybe you can place it on top while you hit the bolt underneath. I might have that bolt, I’ll check tomorrow
Try getting to it from underneath the jeep with a pair of vice grips.
