Winter projects: 2005 LJ & 1998 TJ
ResponsiblyReckless
Flying
Lifetime Supporting Member
Indiana, USA
Winter is here! With the LJ safely tucked away until springtime I decided it was time to find a winter project. I picked up this 98’ TJ in Colorado a few weeks ago, it needs an engine and a good cleaning. I’m starting this thread to document the modifications to both jeeps.
The “winter project” continues. Most of our free time has been spent exploring the US in the Gladiator and LJ, I traded the TJ project for a Gladiator soft top and a few other odds-and- ends.
We took the LJ to the Badlands Offroad park in Attica, Indiana in October and I just had to try that last obstacle. I shredded the ring and pinion and spider gears in the factory 44. I initially thought that I would just rebuild the factory 44, but after peer pressure from my buddies and a few calls to Currie I ordered a set of 44/60 JK Hybrid axles.
I decided to go big or go home and now would be the perfect time to make the jump to 37s, install hydro assist, replace a few seals and gaskets, ditch the factory tank, and do a tummy tuck.
The plan:
Armor: UCF Aluminum deep cover skid system paired with a Genright 19.5 gallon tank, 1” BL, and 1”MML, Genright aluminum corners, MetalCloak rear bumper with frame tie ins
Suspension: MetalCloak 3.5” lift, but elected to run Currie Trackbars, front and rear antirock sway bars, Currie 1” MML, Rokman 1” body lift
Steering: Currie JK to TJ steering, PSC Hydro
Drivetrain: Currie JK/TJ Hybrid 60/44 axles, JK parking brake assemblies, JK brakes, 5.13 gears, Eaton E-Lockers, Tom Woods Super Duty SYE, Tom Woods Front/Rear Driveshafts 1310/1350, new cats
Misc: Relocate EVAP system to accommodate 37s, rear main seal, replace harmonic balancer, timing cover seal, new speedo gear, lower inner shift boot, etc
Electrical: SPOD or Auxbeam switch panel for lockers, future on board air, and aux lighting
Recovery: Badland 12000lb winch (40% off HF special)
As parts started to arrive it was time to start the teardown process.
