Fine, what is your opposing view that doesn't revolve around a position of inexperience?
Again, I'm not claiming experience, you don't have to point that out like it's a revelation to make your point.
The opposing view being that the knowledge and parts are readily available for working through problems with an LS (or any of the other more common options) such as aftermarket kits that fit. Anything can be made to fit anything with enough fabrication, we all know that. But I'm having a hard time seeing that the challenges presented with the Atlas swap are fewer/better than those challenges of a V8 for less power/potential. One of those being the oil pan difference (front sump vs rear sump) that was mentioned. If you're having to custom fabricate an oil pan, that seems like a wash compared to fabricating exhaust. From my understanding, the LS is several inches shorter (front to back) which creates potential challenges for the Atlas and drivetrain package with driveshaft length.
