This weeks video is up. I bolted up a cat-back exhaust and tested it on the rollers.
Did the cheap 62mm throttle body stay on the jeep?
Another weekend treat! Retain the stock catalytic converter or was it non OEM? Just curious as you pointed out so many nuisances can have on the dyno forever and OEM at 250k may not flow so great.
When the header goes on will that down stream cat be retained, upgraded or “test” piped?
Thanks ! , great to see larger exhaust bumps the power . I did enjoy see the bonus hood up dyno . run . Looks like we could all get around 4 h.p. by pulling the hood .Thanks again for doing this Jezza !
Question... if a bolt-on causes it to loose power do I take it off???
Pulled the engine tonight to install the cam and headgasket. It's a bit on the greasy side. I might have to hit it with the power washer as well.
Yeah i was a bit optimistic....I think 30hp is overly optimistic. I think more like 15-20hp on the high side of a big cam which I doubt he's going to run without increasing compression and stock displacement. Realistically without knowing the cam specs, I guess 10'ish hp.
