She said it was painted with "truck bed liner" inside and out.
Posted by "Vikk"
That could the young lady with the baseball cap or the dude with the beard.
Milford CT
Anything is possible.
Posted by "Vikk"
Milford CT
Side noteIn the post she (total assumption on my part, could be a gay coupleafter all it is a Barbie Jeep) said her husband knows more about the mechanical...
Edit:
Suspicion confirmed... "She"
No words for this.. The longer you look at it the worse it gets...
https://www.facebook.com/share/1AbnzHdVMA/
We lived in St. Pete, FL and then Clearwater, FL for a couple years. I never understood Florida Jeep owners. 90% don't wheel. And build the weirdest jeeps for flat land ever. Case in point.
I guess that pretty much says it all right there...
And if I’m not mistaken I believe there…. …Crawling !!!!![]()
Those tile floors are as close to rocks as Florida has.................except @Zorba's old driveway.![]()
p.s. I believe he charged a small fee for daring Jeeps to attempt to climb the mountain. Many have failed.ALL HAIL the mighty ZORBA!
this should solve some problems. Not sure which ones, but some...
View attachment 628525View attachment 628526
Probably the same group I got the picture fromI just saw that on a Facebook group. Turns out these are old Rancho arms. Here's a thread on this forum with them.
https://wranglertjforum.com/threads/lower-control-arm-issue.46767/
Probably the same group I got the picture from. No way if look at that online and think it was a good idea.
Saw this earlier on Facebook. In the comments, there was a discussion about how tire sizes are nominal and actual sizes are smaller.
Someone said “you have to remove the winter air from the tires and replace it with summer air which is warmer and will make the tire the right size.”
Every once in a while, I am flabbergasted at the raw, unsounded depths of stupidity I witness. That was one of those moments.
