I unboxed my new Bambu PS1 and made my first print. It's overengineered, and I could have solved the issue with a stack of washers…
I recently purchased a Switch-Pros 9001 switch panel and a Motobilt mount. Unfortunately, I realized the switch panel would not fit in the mount properly when I snapped on the accessory that placed raised boxes around the flat switches to make it easier to positively locate the right switch while bouncing down the trail.
The solution was to create a spacer that pushed the switch panel 4mm forward, Which allowed the panel to register correctly in the hole with the face plate installed.
Long story short, I make a flat piece of plastic with some holes in it.
Just to be clear, I only made the flat piece.
